Attn: glennster
Posted by Dr. Bert on November 25, 2008 at 11:36:18 from (72.36.57.58):
I have several questions in regard to your reply to my recent post about mounting an IH hydraulic pump on my '49 M. 1- to plug the top 2 mounting holes would you use a regular #5 bolt? 2- how deep would you advise drilling the new holes? 3-- what is the consequence if you drill too deeply? The pump I have has the bottom two holes enlarged so one of the top bolts will screw into the front cover--leaving the top outside hole to be plugged and redrilled. To be sure that there is enough casting around each hole, should I plug and redrill BOTH top holes? I thank you.--Bert
