Posted by Bob Kirk on November 25, 2008 at 13:52:57 from (74.46.243.186):
My 1955 IH 300 utility has been known for starting first time every time. But lately, including today, it has failed to fire at all after sitting for a week or two. I have replaced all ignition parts including the coil, but today again there is no "pop" at all.
But as soon as I hooked a hot wire from the positive side of the battery to the positive side of the coil, she fired right up.
Something in the back of my mind tells me that this means the ignition switch is bad or I have a bad wire between the switch and the coil.
Is this correct? Can I identify which wire runs to the coil just by looking at the back of the switch?
This tractor is 12 volt, negative ground. It has some kind of ceramic gizmo mounted on top of the coil that the positive side wire goes in and out of -- I think for regulating voltage to the coil? Could this gizmo be my culprit?
By the way, is there any downside to running the tractor temporarily with a hot wire from the battery to the coil?
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
