Posted by El Toro on November 25, 2008 at 16:13:57 from (205.188.116.73):
In Reply to: Bad Ignition Switch??? posted by Bob Kirk on November 25, 2008 at 13:52:57:
You need to use a volt meter or test lite to check for voltage at the coil with the ignition switch on. That may be a ballast resistor on your coil for dropping the battery voltage from 12 to 6 volts to the coil.
If there's no voltage at the coil you need to trace that wire from the coil back to the switch. Once you find where the wire is connected on the switch use your volt meter to see if there's battery voltage where that wire is connected. Your switch still needs to be on. If there's voltage at the switch you need to run a new wire from the switch to your coil. Hal
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
