Re: Front end Swap
Posted by Randy in NE on November 25, 2008 at 14:27:36 from (204.124.193.192):
In Reply to: Re: Front end Swap posted by RustyFarmall on November 25, 2008 at 12:18:32:
I'm sure that this topic has been discussed before. If I remember right the consensus is that they do not directly interchange. Larger hole spacing on the M. Adapter plates are definitely an option.
