You need to redo the TA adjustments. The TA clutch is not releasing completely with the main clutch released. That is what is causing the tractor to not roll backwards while in a forward gear. If you have it in reverse, it will not roll forward. With the TA properly adjusted so that the TA clutch releases, the tractor will roll in either direction.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
