300 won't roll when in gear
Posted by Bkpigs on November 26, 2008 at 08:46:57 from (75.132.238.145):
I finished restoring my tractor a while a go and used it for many years before the restoration. One thing that I noticed after I finished the work was that the tractor would not roll backwards when the tractor is in a forward gear with the clutch disengaged. It also wont roll forward easy either. Before the restoration the TA was out and I rebuilt it during the project. could this be the result of having a working TA. PS the clutch does disengage completely and is easy to shift and does not stick.
