Re: 300 won't roll when in gear
Posted by Kevin Meier on November 26, 2008 at 13:57:08 from (208.90.10.236):
In Reply to: 300 won't roll when in gear posted by Bkpigs on November 26, 2008 at 08:46:57:
Did you install the ramp and rollers the right way and install the spacer below the rollers correct?
