Posted by glennster on November 26, 2008 at 14:41:59 from (76.222.57.166):
In Reply to: 6V starter in cold weather posted by 1942 A doesn't like cold on November 26, 2008 at 14:20:23:
i'd be leaning to a starter rebuild. if it cranks slow, and the battery and cbles are all clean, the starter is prolly drawing too many amps. check the brushes for wear, and also check the bushings on either end of the armature shaft. if the bushings get wore, the armature gets pulled off center and takes a lot of amps to get it to spin. napa usually has the bushings in stock, or they can order them for you, or you can take it in for a rebuild, usually costs 80 -100 dollars.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
