1466 TA problems
Posted by BillfromIL on November 26, 2008 at 21:50:24 from (206.71.203.188):
I just had a chance to use a open station blackstripe 1466 I bought. I used it behind a 15ft disc just to pull it a little. The TA appeared to slip a couple of times so I unhooked the disc, checked and replaced the tellite, adjusted the ta linkage so the snapring bottoms out. The tellite comes on when clutch is depressed and dump valve is adjusted. When I put it in high third it slips in high and low both with hard braking, no light though. I don't have access to a manual until next week and have fours days off work to check out the 1466. Where do I check the mvc pressure to the clutches? Any other suggestings? Pictures would be great. I've scanned the archives for the answers and have not found exactly what I need.
Thanks!
Bill
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
