Re: 1466 TA problems
Posted by MHMalcolm on November 27, 2008 at 19:46:55 from (67.242.189.131):
In Reply to: 1466 TA problems posted by BillfromIL on November 26, 2008 at 21:50:24:
If you have slippage in both ranges, it definitely sounds like your main engine clutch is slipping. As others have said here, low range is usually what gives slipping problems. High range hardly ever slips, and I have never seen a TA slip in both ranges. If you find it is the main clutch that is the problem, I have a remanufactured clutch kit available that has a 6 button heavy duty disc, heavy duty pressure plate, and new release and pilot bearings for $423 plus shipping (amount depends on your location). No core is required. If you are interested, e-mail me.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
