Re: Farmall M smokes light smoke occasionally
Posted by Janicholson on November 29, 2008 at 06:50:40 from (209.191.204.169):
In Reply to: Re: Farmall M smokes light smoke occasionally posted by RustyFarmall on November 29, 2008 at 05:49:56:
I know from experiences I have had that the amount of oil put in can influence the outcome. a max of one teaspoon, or two squirts from a trigger type oiler is all that is needed. More just takes up space in the combustion chamber and makes the effective compression substantially higher.
If prolonged idling makes continuous smokeing, or a down hill run in high gear usung the engine as a brake (throttled down) causes serious smoking for several seconds, the guides are suspect. I do believe in umbrella and Perfect circle style seals. It is a interum solution, and can work well for less money. JimN
