Posted by Kelly C on November 29, 2008 at 19:40:02 from (75.161.209.176):
Finally spending some quality time with my 400. Last time I used it. It was not running very well. Charging system was not working and was spitting and sputtering with a fuel problem.
Now I got her in the shop. Took the tank off, carb off, Cleaned out the tank, put on new fuel strainer, rebuilt carb, changed oil and filter, replaced coolant. Put in a new set of plugs. Figured it was a good time for a test drive. Turns over fine. wont start. No spark!!! Swap out the coil with known worker. No spark. New rotor and cap. No spark. New condencer. No spark. Dont have a spare set of points. So clean them up and check gap. No spark. New plug wire. No spark. New wire from dist to coil, checked wire from coil to switch. No spark.
Grrrrrrr, ok whats left? I really hate elctrical problems.
Any way I got pissed and yanked all the wiring out. Tomorow I will install a 12 volt neg ground, W/ delco alt. Was going to do that any way. Just dont have faith thats going to solve the no spark issue. Hope it does.
Not the 1st time this has happended with this 400. 4 years ago it just died with no spark. I swapped every thing out and still no spark. Went out the next day to drag it home and she started fine. Hmmmmm Any ideas?
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w
... [Read Article]
Latest Ad:
[More Ads]
