Re: Farmall 400 no spark.
Posted by El Toro on November 30, 2008 at 03:59:13 from (64.12.116.73):
In Reply to: Farmall 400 no spark. posted by Kelly C on November 29, 2008 at 19:40:02:
Use your volt meter or test test lite to check for voltage to your coil with points open. You should have voltage on both small terminals on the coil. If there's no voltage check your ignition switch terminal that feeds voltage to your coil. Could be the switch or the wire that feeds voltage to the ignition switch. Run a separate wire from the battery to your coil and see if will start. Your starter solenoid if you have one probably feeds voltage to your ignition switch. Most cars and trucks use this too.
Since you're getting battery voltage for cranking
your ignition switch or the wire from the switch to your coil may be the culprit. Hal
PS: Rub those new points with some 400 wet or dry.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
