Re: Janicholson .....H Carb Float Closing Needle
Posted by Janicholson on November 30, 2008 at 18:07:05 from (66.188.163.79):
In Reply to: Janicholson .....H Carb Float Closing Needle posted by Tweeter on November 30, 2008 at 12:06:13:
Most of the things I would suggest are mentioned. Some new needles can hang up in the bore of the seat. Some tangs on the float have worn spotsthat push crooked on the needle. Float drop keeps the float from dropping so low that the needle gets out of place (crooked) and won't slide up. I would check these factors, Polish the triangular sides of the needle a little with 600 grit paper, or match book striker pad, and put it together. Good luck, JimN
