Posted by Fawteen on December 02, 2008 at 01:34:55 from (72.65.100.163):
I'm getting ready to put the road gear on my F14. I pulled the input shaft out of the front of the trans and compared the gears on it to the gears on the road gear.
Rut-ro, Rastro...
There are two gears involved here: The bevel gear that meshes with the transmission mainshaft, and right behind that a spur gear that runs the PTO shaft. On the road gear, both are about a half-inch larger in diameter with a different tooth count.
Fortunately, the feller I got the road gear from knows more about the situation than I do and sent the transmission mainshaft along with the road gear, so I've got that covered.
It's been several years since I had the transmission cover off . My question is, can I unbolt the bearing carrier on the rear of the PTO, pull the shaft partway out and slide the gear off the other end to change it, or am I going to have to pull the entire PTO shaft out?
If I have to pull the whole shaft, how much of the trans do I have to take apart to get to it?
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
