Re: Installing Heisler road gear on F14
Posted by Ron Weber on December 02, 2008 at 17:37:29 from (205.188.116.73):
In Reply to: Installing Heisler road gear on F14 posted by Fawteen on December 02, 2008 at 01:34:55:
The transmission for a f-14 is different from a f-12. The f-14 runs at a higher RPM so the input gears on the trans had to be changed to adjust for the increased RPM's. The best bet is to take the top cover off, drain the oil, and then pull the PTO out from the rear cover. It's a job to do; but when done it is fun to have. Good Luck.
