Yes, this pump enough flow to operate both a loader and power steering. You will have to use a priority flow divider though. The flow divider diverts enough flow to the power steering FIRST (the flow is adjustable) then whatever flow is left is sent to operate the loader, rear remotes, or whatever else you want it to do. Another thought, this pump is driven off of the cam gear and the load of the pump puts more stress on that gear and can cause the cam gear to break. You may want to consider replacing the cam gear with the heavier-duty cam gear off a Super M, 400 or 450. Some people have not used the heavier cam gear with the engine driven hydraulic pump and have claimed to have had no problems, while others were not so lucky. I guess the choice is yours, one the one hand it is not quick and easy to change the cam gear, but if you do not change it and the gear breaks, then you will be forced to change it along with anything else that broke when the cam gear did.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
