Posted by Bob M on December 07, 2008 at 18:58:24 from (74.74.136.142):
In Reply to: SMTA Fan Belt Pulley posted by GordoSD on December 07, 2008 at 18:01:32:
The adjustable flange is right hand threaded onto the hub. To tighten the belt turn the flange clockwise as viewed from the fan.
How to turn the flange? I use a long punch engaged into any convenient flange "lug" and tap with a hammer. Hold the fan from turning with a scrap of wood wedged between a fan blade tip and shroud.
Be sure to remove the locking set screw from the adjustable flange! A shot of your favorite penetrating oil down the set screw hole is often helpful.
Tip: The fan belt SHOULD run "a little loose". 1-1/2" or so deflection under light finger pressure at mid-span is about right.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
