SMTA Fan Belt Pulley
Posted by GordoSD on December 07, 2008 at 18:01:32 from (66.115.200.140):
Trying to tighten the fan belt on the SMTA. Which way does the fan, the threaded fan hub, turn in the belt hub to tighten? From in front of the tractor?
How do you guys do it? Put a large pipe wrench on the belt hub and drive the fan (threaded) hub with a punch? Don't have enough hands to hold all the tools. It's one of the few parts I didn't disassemble when I restored the brute, But after I ran the old genny belt under it, and a new PS belt under it, and cleaned off some major rust on the crank pulley, the fan belt is a little loose.
Gordo
