Re: international 2000 loader for a 460 utility
Posted by jk on December 09, 2008 at 12:43:30 from (64.112.198.52):
In Reply to: international 2000 loader for a 460 utility posted by zero on December 09, 2008 at 06:26:40:
the 2000 was the "industriel" version of the 2001, and there are some similarites, and differances. the 2001 was a "normal" duty farm loader.i've seen both on tractors as big as a 706, and as small as an M. i have also seen a 2000 loader on a 460 from the factory, the right mounts were availabe, but might be hard to find now.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
