Re: 30 Farmall Regular Carb Problems
Posted by steve il on December 12, 2008 at 04:41:52 from (70.41.51.75):
In Reply to: 30 Farmall Regular Carb Problems posted by ScottyHOMEy on December 11, 2008 at 19:29:32:
Wheel880 said: (quoted from post at 04:29:32 12/12/08) I"ve got a 1930 Farmall Regular with the brass "snail shell" carb. The tractor runs but I have to keep it almost fully choked or it dies out. I"ve had that carb apart a dozen times. Everything is clean and passages open, new cork float, and reset fuel level in bowl up to where it"s just beneath the (overflow?) tube. A test with ether shows no leaks around head or manifold and plenty of fuel out of the feed line (no problems with sediment bowl or filter screen). Anyone out there have any ideas? It"s not an overly complicated carb -just not getting fuel into the engine for some reason.
Hi have you made sure your primeing cups are closed.if they are open or gone it will create vacum leak. Steve
