Posted by Janicholson on December 13, 2008 at 11:13:25 from (64.83.205.193):
In Reply to: OT piston direction. posted by Red460 on December 13, 2008 at 06:37:37:
I think, but do not know, that the center to center distance on the paired cylinders is the reason. each "jug" is treated separately. If you measure the location of the journals on the crank (from one another) and the bore spacing of the two cylinder units. the space between cylinder #2 and #3 (in different castings will require the offsets you have found. If you lay it out it should be clear which way they assemble. I had a 2 cyl Le Roi and it had offset rods on its assembly. JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
