Posted by John G. Hasler on December 14, 2008 at 11:25:27 from (66.112.108.80):
In Reply to: Re: 460 gear clash posted by CNKS on December 14, 2008 at 09:32:51:
Sounds like you have a problem similar to the one I had when I replaced the engine clutch in my 544 last spring. The combination of a new engine clutch and an old TA clutch results in a tolerance stack-up such that when the engine clutch is adjusted properly the the TA adjustments lack enough range to be set so that disengaging the engine clutch also disengages the TA clutch. Result: clashing gears. I suggest that you do what I did: set up the engine clutch to spec and then modify the TA linkage as necessary to get it to work (the 460 linkage is quite different from the 544 one, though). If your TA is too far gone you may need to rebuild it (groan...)
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
