Posted by CNKS on December 14, 2008 at 09:32:51 from (216.144.104.128):
In Reply to: Re: 460 gear clash posted by Janicholson on December 14, 2008 at 06:55:38:
So, you are saying that it is ok for the release bearing to be in contact with the fingers and turn? If so that opens other possibilities. However, I would need just enough tension on the bearing cover so that the fingers do not slip on it. Otherwise they will eventually wear through. In this case, I don't think the clutch will slip if adjusted so that the fingers don't move until the clutch is depressed, but again I can't see inside. It might help if adjusted so that I can stop the bearing rotation with my finger (or amputate my finger if gets caught in the spinning clutch), but the bearing/finger slippage will cause wear.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
