Posted by Janicholson on December 16, 2008 at 10:48:39 from (199.17.6.128):
In Reply to: Re: 300 starting Problem posted by Siefring Red Farmer on December 16, 2008 at 10:40:27:
The voltage drop must be measured at the starter terminal that goes into the starter from the solenoid, with the other lead to ground at the starter. Run the starter and check the voltage. While cranking. (I bet it is less then 4.5 or so volts) that is a load related drop in Battery volts applied top the starter motor. Non load tests would be about that number on a piece of 14 ga wire at that distance. Best of luck, JimN
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only
... [Read Article]
Latest Ad:
[More Ads]
