This is why I replaced the battery cables. I measured it and was getting about .5 volt loss on the power side and .25 loss on the common side. After replacing both cables, the voltage loss is down to .25 volts on both the power and common side of the battery.
Also, the ignition was replaced about 1 year ago with electronic ignition because the shaft in the distributor was getting so loose that I could not set the points propperly, no points to break. The tractor runs fine once started, I just can't get it to crank over to start.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
