Re: QUESTION ABOUT A 1959 140 FARMALL.
Posted by BDC on December 17, 2008 at 16:30:23 from (209.183.32.47):
HI WELL I GOT MY RINGS AND FOUND THAT ALL WERE FROZEN TO THE PISTONS. I HAD 2 OF THE JUGS COME OUT ON ME. I CLEANED ALL SIDES WITH A RAG AND TAPED THEM BACK IN IN THE SAME SPOTS THEY WERE IN. MY QUESTION IS WHEN THE HEAD IS TORQUED DOWN WILL THES JUGS SEAT THEMSELVES WATER TIGHT OR SHOULD I DO SOMTHING ELSE TO MAKE THEM WATER TIGHT. THANK YOU BRETT
TheDurk said: (quoted from post at 17:31:04 12/06/08) One more try at 1960 140:
<img src="http;//www.tractorshed.com/gallery/tphotos/a103590.jpg">
OKAY--someone please tell me what I am doing wrong with this code. Thanks
Today's Featured Article - Converting from 6 Volt to 12 Volt - by Chris Pratt. It's a common problem for old machines especially when the weather starts to dip below 40 and the tractor isn't fired up as often. You are probably used to the 12 volt Diehard, charged with 200 amp alternator of your 3/4 ton that always is ready and always starts. It's this type of experience that brings about the many queries we get for 12-volt conversion kits. Since only a few kits are available (we sell kits for the ... [Read Article]
