Re: Some simple H questions
Posted by CNKS on December 21, 2008 at 18:16:52 from (216.144.104.128):
In Reply to: Some simple H questions posted by H rookie on December 21, 2008 at 18:08:30:
The ports are all pressure. For your purposes it doesn't matter which one you use. SAE 30 is fine, unless it is consistently below 32 degrees, if so use 10W-30 or 15W-40. Multi-viscosity oils did not exist when your tractor was built. You can also use SAE 30 in the hydraulics, some say to use non-detergent in the hydraulics to prevent foaming -- I always used detergent in our H in the 50's with no problems, though.
