Farmall 140 hydraulics
Posted by AgMan08 on December 22, 2008 at 04:27:47 from (152.26.14.3):
I have a Farmall 140 that we are restoring at the High school, and I need help with the hydraulics.
Is there a stick or a plug that you would pull to check the hydraulics?
Where would you add hydraulic fluid if lift will not raise? Since it raised only halfway then went to the ground and we could not get it to lift back.
