Re: Water in oil?
Posted by Bob M on December 26, 2008 at 12:56:45 from (74.74.136.142):
In Reply to: Water in oil? posted by Paul Shuler on December 26, 2008 at 10:36:09:
Paul - You absolutely certain what drained is antifreeze and not just condensation? With your infrequent use of the tractor - and mostly in cold weather - a small amount water condensation in the oil is not unexpected.
Now if it IS antifreeze, 3 - 5 cc lost in 2 years is NOT very much. Suggest putting a can of sealer in radiator then running the engine per instructions on the can. And the next few times you use the tractor, loosen the drain plug, catch an ounce or two of oil in a glass container and see if antifreeze is still getting into the crankcase.
