Re: Jump starting an 8-volt system with a 12- volt system
Posted by bthansen on December 27, 2008 at 18:55:51 from (74.220.15.200):
In Reply to: Jump starting an 8-volt system with a 12- volt system posted by Ireland on December 27, 2008 at 17:48:39:
Doesnt matter where you hook it up. The cables are going to run it back to the battery however you hook it. Ive done it many times, just hook it up to the battery just like anything else but dont leave them on there very long because it will boil the battery. Hook up, get on the tractor and start. Then unhook right away.
But as far as hooking on the starter or battery it will go the battery either way. Infact a 6v system has heavier cables then a 12v because it carries more amps. Volt x amps = watts so if you have 6v it takes more amps, thus heavier cable. 12 takes less amps to do the same work, so you can use lighter cables. One thing we were taught in school was that most starting problems comes from poor cables, cable ends, and connection. Found this to be true more times then not.
hope this helps.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
