Posted by ChadS on December 28, 2008 at 06:48:08 from (4.224.78.176):
In Reply to: New sleeve is to loose posted by J Muehring on December 28, 2008 at 05:57:42:
Ive used Loctite sleeve retainer, had good luck. The head torqued down should hold the sleeve down in the block, but watch for it being out of round,,, Shouldnt, but its possible,, When I glued em in, Ill use the loctite on the block bores, then as I drop in the sleeve, Ill dab a little more in as I drop in the sleeve, I spin the sleeve while I drop it in,, so the glue spreads over even, or as best as I can get it for best coverage between the block and the sleeve. Then, set the head hasget on and the the head, with the gasket, torque the the head down so it sets the sleeve with downforce pressure, when the glue dries it should not move. Hope this helps. ChadS Thetractorshop.com
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
