Re: Rockford clutch question
Posted by Gene Bender on December 29, 2008 at 11:38:04 from (67.55.226.75):
In Reply to: Rockford clutch question posted by DRC on December 29, 2008 at 10:22:36:
Are you sure you have the clutch plate in correct and not backwards. Have you adjusted the linkage so you have 1in free play before the throw-out bearing enguages the fingers. The Cs can have a lot of wear in the pedal shaft.
