If the driven disk hub gets a bit stuck on the splines if the clutch shaft, or is running in wear grooves from the prior clutches, it will definately rub its new face on the flywheel and drag. Sometimes enough to keep shifting from happening. A bent hub from a bit of juggeling with insertion will also cause the same issue. Keep us informed, JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
