Re: worn clutch pedal shaft on M
Posted by Nebraska Kirk on January 01, 2009 at 16:10:28 from (207.91.4.202):
In Reply to: worn clutch pedal shaft on M posted by Charlie M on January 01, 2009 at 15:39:54:
The only way I can think of to repair the worn shaft without removing it from the tractor is to weld it up and grind smooth, it would be easier to do if it was removed though. It would be better to put the shaft in a lathe and turn it back to size after the worn area is welded up, it would be round and smooth that way.
