worn clutch pedal shaft on M
Posted by Charlie M on January 01, 2009 at 15:39:54 from (70.101.104.228):
The clutch pedal shaft on my M is worn pretty bad and gives the pedal a lot of side to side play. I've replaced the pedal with one with a good hole. Anyway to fix the shaft without removing it from the tractor. I'm guessing not but I know somebody knows all the tricks if there is one.
