Need Wiring Diagram
Posted by Willy Hall on January 01, 2009 at 16:16:47 from (205.188.116.73):
I have a circa 1950 Farmall Cub that I'm trying to convert from 6 volt to 12 volt.This tractor has a magneto ignition system. I have installed a Delco-Remy alternator(61A6H13) This unit has a threaded post on the back and 2 spade terminals along the outer edge at the back. I am at a loss as to what to do with the ends of the two wires that were attached to the discarded voltage regulator. One wire ran between the ammeter and "Bat" terminal on the regulator and the other between the lighting junction block and the "L" terminal on the regulator. Thanks
