Posted by Janicholson on January 01, 2009 at 18:09:33 from (64.83.200.187):
In Reply to: Need Wiring Diagram posted by Willy Hall on January 01, 2009 at 16:16:47:
The lighting wire going to the L terminal can be connected directly to the load side of the Amp meter. The Big screw terminal on the Alternator goes to the same terminal (load side of amp meter. The #2 terminal goes to the big screw terminal also. The #1 terminal should go to a wire attached to a oil pressure switch (purchases at a NAPA store, this switch has two terminals and is open when there is no pressure) "T"ed into your oil pressure gauge or line to the gauge. The other terminal of the switch is connected to the positive battery terminal at the starter switch (where the supply to the amp meter is connected (that big post on the switch with the battery pos cable hooked to it.)) THis setup causes the alternator to start charging as soon as the oil pressure is up., and stops charging when the engine is off. No diodes or other stuff needed. I would put a 70 amp Fuse link in the wire going to the Amp Meter from the start switch. As mentioned below, do not connect anything to the ignition. JimN
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
