Re: 460 brakes
Posted by J.J. from Afton on January 01, 2009 at 18:08:03 from (12.208.127.84):
In Reply to: 460 brakes posted by stevo944 on January 01, 2009 at 13:02:53:
Depending how bad they are you may have to machine (or have them machined) the sucrfaces, of the housings and the exapneders. The best way to do this is in a lathe. You should also take the expanders apart by popping the springs off and make sure the balls and grooves are clean. If not just use a 3/4" or 1" wire brush in a drill and clean them up.
If the balls are badly worn you can get them from CaseIH along with springs if needed. The brake pads can be bought from numerous places, CaseIH is the best cause they sell ones that wont lock up.
Hope this help you
-Jordan
third party image
third party image
third party image
third party image
