Posted by bc on January 02, 2009 at 09:07:27 from (68.88.175.43):
In Reply to: Re: 460 brakes posted by J.J. from Afton on January 01, 2009 at 18:08:03:
Same setup as my 2606. A straight edge along the rotor surface and mounting holes on the rear end showed them as perfectly flush.
I cleaned up ball and groove area and put a little antiseize on the balls/grooves to lube them. There may be something better as long as it doesn't run onto the pads. I didn't bother with cleaning the pits on the actuator/expander as I would let the brake action clean them up instead. This isn't quite like stopping a car. I don't road mine, just slow speed stuff moving bales and dirt work and setting the brake.
I see you machined your housing, JJ. I laid the disks and actuator in the housing and laid a straight edge on the housing and used feeler guages underneath. Ended up leaving a few thousandts space and took off about 10 to 12 thousands. The machine shop I used didn't want to try to chuck it up in a lathe with those bolt hole extension in the housing and he used some type of surface grinder. Charged me $45 for one.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
