Posted by Wardner on January 01, 2009 at 22:37:53 from (4.154.242.56):
In Reply to: SMTA Battery/Starter posted by Idaho Boy on January 01, 2009 at 20:12:06:
Deep cycle batteries can't deliver the "cold cranking amps" that an automotive battery can.
Take a battery out of your car or truck and see if that makes a difference.
Having said that, I run two heavy deep cycles in my Dodge Cummins. It will start down to 10 degrees without connecting the block heater. The engine does turn over more slowly with the deep cycles. I use the batteries to power 12V pumps when scavenging fuel from domestic fuel tanks. They are also better for running 12V winches. I expect these batteries will last much longer than the typical automotive batteries.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
