Re: worn clutch pedal shaft on M
Posted by James Rumph on January 02, 2009 at 04:58:20 from (24.192.125.175):
In Reply to: worn clutch pedal shaft on M posted by Charlie M on January 01, 2009 at 15:39:54:
If i do recall the clutch pedal shaft and brake pedals shaft just slips out. It is a common shaft for all three pedals that doesn"t connect to anything inside.
It is just cold roll steel that needs a key way slots put back into a new one [ woodruf key ] so i don"t get called on this one. Any automotive machine shop with a Bridgeport can do this or maybe some you know that might have one.
My dad did this to his W-6 and it was very easy. There is plenty of bone yards that you might find goog pedals etc that are not worn.
