Re: SMTA Battery/Starter
Posted by GordoSD on January 02, 2009 at 06:27:51 from (66.115.200.140):
In Reply to: SMTA Battery/Starter posted by Idaho Boy on January 01, 2009 at 20:12:06:
What size is the cable running to the starter motor? It should be at least an 0 and preferably a 00.
Feel the switch after cranking. Is it getting hot? If so your cable is too small.
Double check the ground. Remove it and sand it and the point where it connects to the tractor.
Get a reguular hi=cap battery.
Gordo
