The block has some small dings in it around where the #4 sleeve fits in the block and it is lower than the other three. This is why I believe the problem is with that cyclinder.
I put new rings in it last spring and when I put the head back on it, it did not seal. When I first got the tractor I had the same problem and I tried some Stop Leak in it and it stopped the leak.
If I run it for a couple of hours, I will get about three tablespoons of antifreeze out of the drain and the oil starts to look nasty.
Before I put the head back on, I took it to work and it is flat to within about .003 if I remember correctly.
I do not have a heated area to work in and I do not want to take the head off this winter and I do not want to wreck this engine, after putting the new rings in it. Thank you Steve
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
