Re: Bar's Leak Head Gasket Repair
Posted by Janicholson on January 02, 2009 at 21:07:42 from (68.112.156.69):
In Reply to: Re: Bar's Leak Head Gasket Repair posted by SDE on January 02, 2009 at 14:51:17:
If it is getting in the oil, use the bars leak. No issue there. It may have a cracked head, or cracked block casting at a cylinder, leaking into the pan at the sleeve. (between the dry sleeve and block bore. Best of luck, JimN
