Re: worn clutch pedal shaft on M
Posted by 510plows on January 02, 2009 at 19:05:01 from (216.188.193.191):
In Reply to: worn clutch pedal shaft on M posted by Charlie M on January 01, 2009 at 15:39:54:
Glade to see people are still fixing up these old girls. I can help you out with your clutch pedal problem. I have a little machine shop that I work in after I get home from teaching school. I have designed a gig fixture for holding the pedal in a bridgeport so I can bore out the pedal to install a brass bushing. I also build new shafts for different Farmall tractors. I have found it's cheaper to make a new shaft than trying to build up an old shaft and turning it back down to size. My e-mail is open
