Re: 460 problems
Posted by El Toro on January 03, 2009 at 09:33:33 from (205.188.116.73):
In Reply to: 460 problems posted by Nebraska Kirk on January 03, 2009 at 08:15:56:
Hold your hand over the throat of the carburetor and see if there's good suction while someone makes an attempt to start the tractor. You need good manifold vacuum to pull that fuel into the engine. You can run a separate wire from the battery to your coil to eleminate the ballast resistor. When they're bad the engine will start as long as you're cranking the engine for a few seconds. Hal
