460 problems
Posted by Nebraska Kirk on January 03, 2009 at 08:15:56 from (207.91.4.223):
I am working on a 460 for my great aunt, trying to get it running after sitting outside idle for over a year. I have gone through the carb, replaced the spark plugs, plug wires, points/condenser, rotor, and distributor cap. I can"t get it to start and run for more than a few seconds. I have double checked the timing, tried advancing and retarding it a few degrees, did not seem to help. The couple of times it has ran a few seconds was with the throttle all the way open and the choke about halfway out. I am getting kinda POd and could use some advise & suggestions!
