Re: worn clutch pedal shaft on M
Posted by Randy-IA on January 03, 2009 at 09:51:16 from (207.177.83.135):
In Reply to: worn clutch pedal shaft on M posted by Charlie M on January 01, 2009 at 15:39:54:
I did basically the same as Henry did but I used soda can metal. A quick poor fix at best for mine. A new shaft is available from many sources but cost over 50 bucks. Getting one made should be a lot cheaper. If you pull that shaft install new seals on both sides. Good Luck! ...Randy
