Re: SMTA Battery/Starter
Posted by mattofvinings on January 03, 2009 at 10:38:08 from (24.178.75.169):
In Reply to: SMTA Battery/Starter posted by Idaho Boy on January 01, 2009 at 20:12:06:
Brownie 450 said: The star washers provide extra current carrying capacity.
I would agree that the star washers help "bite" thru any surface problems by increasing contact pressure in the areas where the "stars" are turned.
However, a good bright-clean flat area with a tight bolt or nut will conduct better due to more area in contact.
One trick if you are in desperation is to use copper-based anti-seize in the connection. The copper will aid conduction until you can repair it properly.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
